Ques. about horsepower.
Old 08-30-2008 | 11:52 AM
ny06fxdb's Avatar
ny06fxdb
Default Ques. about horsepower.
Is it possible to get over 100hp without a big bore kit?
Old 08-30-2008 | 12:01 PM
EvEr34's Avatar
EvEr34
Big bore kit on what?
Old 08-30-2008 | 12:09 PM
wafu321's Avatar
wafu321
Sure it is. With head work and the right cams it can be done.
Old 08-30-2008 | 12:17 PM
ny06fxdb's Avatar
ny06fxdb
thanx. I am thinking of building up a new superglide next year. just weighing my options.
Old 08-30-2008 | 01:32 PM
JRK5892's Avatar
JRK5892
Turbo
Old 08-30-2008 | 01:45 PM
drtheo's Avatar
drtheo
Procharger, just kidding. I think that I would rather have over a 100 torque than HP, but thats just me
Old 08-30-2008 | 05:36 PM
Danielson's Avatar
Danielson
Thumbs up yes
The newer Dyna's are set up with all the torque you need,as far as the big bore kit is concerned -if your looking for more nut that set's you apart for whatever reasons try the SE 103 kit without the cams then add Andrew twin Cams with the SE clutch kit.Don't know about anyone else but it works for me.
Old 08-30-2008 | 09:05 PM
new_mentor70's Avatar
new_mentor70
no matter what you will need some additional cylinder presure, and head work, with cams. but as stated earlier, its the torque that matters!
Old 08-31-2008 | 10:09 AM
sharkey's Avatar
sharkey
One of my riding buddies has a 102hp 88inch but if you ride it and look at the dyno sheets you find the torque spread is narrow and high compared to the same hp with more cubes, generally speaking. If you're cool with just a "peak" number, go for it. Myself, I really enjoy the 100ft lbs I have starting at 2200 rpm with my 103...check some dyno charts out from 2000 to 5000 rpm and you'll see what I'm talking about...a lot of the high hp builds don't even start the chart until 2800 rpm or higher.
Old 08-31-2008 | 10:52 AM
FATBOB.'s Avatar
FATBOB.
your right SHARKEY. on low rpm motor, 5000 to 6000 red line engine
it is better to have lower torque around 2500...
