Power Commander
Power Commander
I just installed the PC III and the K & N Filter on my Fat Bob. The PC III was ordered through FuelMoto.com and was premapped for my exhaust and filter, should I have it dynoed? Howw would I tell if it is not running properly with the map that is on the PC III when I bought it????
Thanks
Thanks
I got my PC III for my StreetBob from Fuelmoto mapped for my pipes and airbox I specified. I have no issues with performance or with popping using the map supplied. I'm not happy with the fuel mileage but I can live with that as I use my RoadKing for any long distance riding.
Would I have it Dyno'ed - only if I was looking to wring every once of performance out of my current set up. And, even then, I don't know if I would, in the really world, actual be able to see or feel the gain I would get from putting it on a Dyno. Guess my suggestion is to live with the map supplied by them unless you are experiencing performance problems.
I also bought my pcIII from fuelmoto. I nstalled a new a/c and wasnt going to wait for fuelmoto to send me a new map so I downloaded the new map from dynojet. It ran great but the fuel milage sucked a$$. I called dynojet tech line and the tech lowered the map 5% from 3000 to 4500 rpms. The fuel milage went from 34 to 42mpg. I was very happy with the tech support from dyno jet
Norris
Norris
Thanks
Thanks
did they give you the disc? And I was told not to waste my money on a dyno tune unless you do engine work. I used to have alot of problems with my bike popping on decel alot, I had to re-map it myself, of course with the help of "Piginablanket". He sent me a copy of a map.
Oh yea and that air cleaner you have looks familiar.
