Sears Yellow jack
muderator
The HD adapters are what you want. Around 20 bux.
I put some info here a while back (postings 9 10 and 11)....
https://www.hdforums.com/forum/dyna-...ml#post2469782
Today, I added this to the info at that page.........
08 23 08....... I am adding the info below........
A few weeks ago I had a look under the lift for the first time
after using it quite often over the last three years.
Next two pix are the main pivot for the platform.
I noticed that the shoulder bolts were backing themselves out.
The one shown on the left below was almost coming off the main shoulder.
I put a drop of Blue ThreadLocker on both of them.
Had the engine out and took the shot below clearly illustrating placement of the HD adapters.
The two fronts ones are on frame directly in front of footPeg mounting point.
Rear left side goes on the frame directly behind the point where the frame bends.
mud
bobbyd3
08-06-2007 09:01 AM
