Does the Thunderslide make much difference?
I installed the screaming eagle kit made by dynojet...(the same dynojet kit they sell for 85-95 for only 75)
made a big difference in performance and throttle response over changing out just a low speed jet and shimming the needle(as well as other home remedies)...
I for one will say get the basic kit and install it...I did not get the thunderslide from dynojet. that is more for a bike that has had internal work done to motor not for stage one (at least from what I read at dynojets site).
the only difference I personally had over the instructions is they recommend starting your air fuel 3.5 turns out...that is too rich for my bike I run it 2.5 turns out.
bike completely woke up with this kit...
I just installed a thunderslide kit in my 2002 Electra Glide and believe that it made a big difference. It's stage 1 and I went to rejet and found that someone had already changed the emulsion tube so I couldn't buy a bigger main jet that would fit locally. Spoke with a few people and bit the bullet on the kit price and put it in yesterday.
I haven't had the Glide long but it felt pretty weak in throttle response on the highway compared to the RK I used to have and I was always shifting back and forth between 4th and 5th running 55 to 65 mph. After installing the kit now I can just give it a little more throttle at 55 to 60 in 5th and it'll roll on up. I don't lug but am not shifting as much. Granted I have one day with it so far after the install but will see.
The kit also came with a coupon for a free dyno run so that makes the price of the kit a little easier to swallow. Maybe just a bigger main jet would have done this but I'm happy with it.
DRAGO'S BIKE WORKS
Vendor For Sale Classifieds
14
01-28-2011 02:11 PM
big, clutch, davidson, difference, evo, harley, installed, installing, kit, make, rich, runs, slide, thunder, thunderslide
