Tachometer fitted
Tachometer fitted
My Tachometer arrived and I had them fit it while doing the 1k service, I think it looks great and finishes off the look, see thumbnail pic not the best as I had to use the flash, Tacho gauge face color is the same as the Speedo, if you do the recommended speeds for changing gears as recommended in the manual i.e. 1-2 = 15 mph 2 -3 = 25 mph 3-4 = 35 mph 4-5 = 45 mph 5-6 = 55 mph the revs are between 1500 and 2000 rpm,
