Stock 96 pistons/jugs with headwork and cams?
Old 08-13-2008, 11:31 PM
rok312's Avatar
rok312
rok312 is offline
Default Stock 96 pistons/jugs with headwork and cams?
Seen plenty of posts on 103, 107, etc upgrades...but has anyone with a 96ci/'07+ just kept their stock cylinders/pistons, but gone with headwork AND cams? If so, was it worth it, or is the cash outlay such that you might as well spring for the big bore? What kind of numbers are you seeing?
Old 08-13-2008, 11:37 PM
Bluesssman's Avatar
Bluesssman
Bluesssman is offline
What you are describing is the best bang for your buck. If you have your heads reworked and and cams, you will make more power than increasing your cubic inches.
Old 08-13-2008, 11:54 PM
rok312's Avatar
rok312
rok312 is offline
Thanks for the feedback, Bluessman.
By the way, if anyone has any suggestions on a good place to have headwork done and good cam choices for a stock 96 with headwork, do tell.
Old 08-13-2008, 11:57 PM
mud's Avatar
mud
mud is offline
muderator
Received 9,112 Likes on 2,120 Posts
Why, exactly, would you say something like this??
mud
Old 08-14-2008, 12:43 AM
newrench's Avatar
newrench
newrench is offline
If you added compresssion to those heads and cams with 96" it would go real well.
a 103" with same set up would go even better.
Old 08-14-2008, 12:58 AM
paul s's Avatar
paul s
paul s is offline
There is no substitute for C.I.D. more cubes = more power. It depends on what you are willing to give up, thin cyl. walls = more heat. Highlift cams= more topend less lowend power. Heavy porting will lose lowend power. It's all about having a matched combination. A well tuned engine will smoke a missmatched engine. It's where do you want your powerband.
Old 08-14-2008, 01:28 AM
sick_dyna's Avatar
sick_dyna
sick_dyna is offline
davemackie.com
he has proven to be the best of the best. You can do exactly what u are describing through dave mackie. I know because this is exactly what I plan on doing to my bike.
Old 08-14-2008, 01:03 PM
Mr Wasabi's Avatar
Mr Wasabi
Mr Wasabi is offline
What cams do you guys recommend to use on a 96? Andrews? Stick with SE? The other engine mods are V&H Big Radius pipes, Ness Big Sucker and a PCIII. Do I need to have the heads worked on to make a cam upgrade worth it? I'll probably swapout to the V&H 2 into 1 Big Radius pipes also.
Thanks.
Old 08-14-2008, 03:43 PM
Koppster's Avatar
Koppster
Koppster is offline
Can't speak directly to Harley's but we do this all the time with motocross engines (4 stroke). Port the heads, change the cams and sometimes valves and springs. You will gain some horsepower but not as much as you would on a bore (no replacement for displacement). The bike runs better, the power bands tend to be wider and the response is snappier in most cases.
Also concur with all of Paul S's post. Best to have someone you know and who knows you do your port work and match cams, etc.
Rick's .02
Old 08-14-2008, 03:50 PM
sick_dyna's Avatar
sick_dyna
It depends, if your plan on keeping your bike for a while, a gear driven cam is best. If you know your going to eventually get rid of your bike, a chain driven cam would be the better, cheaper way to choose a cam. Andrews has both kinds of cam. The gear driven cam is usually about 400 dollers more.
Quick Reply: Stock 96 pistons/jugs with headwork and cams?
