Strange sound while riding !!!!!
Hi guys
I just noticed recently that I hear very strange sound while accelareting the bike. The sound comes from the back or from the motor itself.I could not recognize what it might be. Dropped at the dealer and hd tech told me it is the usual sound of harley bikes.But it is strange that I hear it after two years.....Anyone experienced the same....
thanks in advance for yr nice comments
06 wg hdi
06 wg hdi
Just noticed a strange sound from my 08 LR this past weekend. Probably because I was riding with my windshield on.
The sound I heard was when crusing along 40 or so (bike was not lugging either and rpms at a nice level), then hitting the throttle hard, I'd hear a kind of squeal that was short lived... lasts about a second.
Sounds like a cross between a metal to metal squeal and a rubber belt squealing on a smooth pulley.
That's the best I can come up with what mine sounds like and seems to come from the left side of the engine.
When riding normal, it's fine and no odd sounds.
I'm under warranty, so I'm not going to worry about it for now.
Could be the clutch?
Hi guys
06 wg hdi
06 wg hdi
Not knowing what he sound is, the best advice I can give is the three rattle, sounds, I have had on my 06 low rider.
The first was the inner bearing, this was definitely a whirring sound that became progressively louder as miles racked up. This happened around 12k; however you can definitely tell this one, that is you have good (mechanical) hearing.
The second wired noise I has was the wiring harness under the gas tank, it would periodically vibrate and sound like the motor starting to have a strange rattling, vibrating sound.
The third is funny, only under hard acceleration, I would get this rather loud rattle, there then gone.... Turned out to be the plastic plug on the bottom of the fuel gauge had fell off and was rattling around the bottom of the where the fuel gauge is mounted. I hope this helps, but as before not knowing the noise.
Is this the same noise you get?
When I hit the throttle hard in higher gears, I get a strange squeak.
This does not occur under normal conditions.
It is more pronounced when it is in a slightly lugged condition.
For example, if I was to let the RPMs fall to 2000 in 5th gear and got on the throttle hard, it would chirp, squeal, squeak or what ever you call this noise.
i can also produce the noise when i am stoped. i hit the throttle hard as it comes down i hit it again and it will chirp, squeal, squeak or what ever you call this noise.
does anyone know what the noise is?
