Belt tension adjustment question
its in the manual.it has tension for both off the ground and on the jiffy stand. i usually adjust off the ground and double check on the ground. do not get the belt too tight. i adjusted right to spec and ended up getting a new inner seal. the tech at the harley shop and i agree that at least 1/8" more than spec is as tight as one should get. as you run it you will notice that the sprockets expand and the belt tension will tighten.
good luck
scott
good luck
scott
According to the service manual, the belt should be checked for proper tension with the approximate rider's weight on the bike. As weight is added, the swing arm moves, slightly changing the distance between the spockets and changing the belt tension.
If the adjustment specs are achieved without rider weight on the bike, the belt may tighten when you are on the bike causing added tension and stress.
Adjust the tension while someone who weighs about what you do is seated on the bike.
