Air Filter Cover
Old 03-16-2006, 03:44 PM
jhampshire's Avatar
jhampshire
jhampshire is offline
Default Air Filter Cover
I have a TC-88 engine with the oval air filter cover. I like the looks of the old round Evo cover and I wonder if there is any reason I should not use one. Do any of you know? I tried one on and it appears to fit perfectly.
[IMG]local://upfiles/2974/A0ACABDC4B054F9DB1CDD78BA566A175.jpg[/IMG]
Old 03-16-2006, 05:12 PM
phreak's Avatar
phreak
phreak is offline
Default RE: Air Filter Cover
I'm running the round Nostalgia cover on my Bob. You need an extra rubber gasket to go on top of the SE philter, or even the K&N philter.
What I don't much care phor is the way the round cover touches the *ears* of the SE backing plate where the breathers attach to the cylinders.
It should work though, provided you get the gasket.
Old 03-16-2006, 06:27 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
reason #1 not to use it: It will make your engine look like an old evo
Old 03-16-2006, 06:59 PM
phreak's Avatar
phreak
phreak is offline
ORIGINAL: KBFXDLI
reason #1 TO use it: It will make your engine look like an old evo.
But then again, I would like my Bob to have the look of an older bike, while having the technology of a new one.
Old 03-16-2006, 09:21 PM
ameristo's Avatar
ameristo
ameristo is offline
Hey guys I did away with the cover altogether and bolted just the insert directly on top of my SE air filter element.
[IMG]local://upfiles/6102/A2FF73756B984053A2A955FDFCA0AD9D.gif[/IMG]
Old 03-16-2006, 10:50 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
ORIGINAL: phreak
ORIGINAL: KBFXDLI
That's cool if you like retro.........I like the large shiny oval cover........your eyes are drawn to it.
Old 03-16-2006, 10:55 PM
06dynablack's Avatar
06dynablack
06dynablack is offline
I am running the round evo cover myself.I dont have no extra washer between the se filter and coverfits tight the cover to filter and the backsideof cover is against the ears.whats the idea of the extra washer ?
Old 03-16-2006, 11:37 PM
tb2377's Avatar
tb2377
tb2377 is offline
azece.com make som cool round covers
[IMG]local://upfiles/7785/04E5CA35B837447C8E341798A0D183CE.jpg[/IMG]
Old 03-17-2006, 02:20 AM
phreak's Avatar
phreak
phreak is offline
ORIGINAL: 06dynablack
Vibration Isolation. There have been cases of the round evo cover on the newer SE backing plate developing cracks, and phalling off.
It's not a washer, it's a gasket. 'Bout 1/2" thick. phits over the top of the SE or K&N philter, between the cover and the philter. It will screw down with the same bolt that holds on the oval cover, but you may phind problems later. When you put the gasket on, you'll need a different bolt.
Old 03-17-2006, 01:45 PM
06dynablack
thanks phreak for the explanation
Quick Reply: Air Filter Cover
