Balancing Beads
Old 01-26-2010, 08:44 AM
rounder's Avatar
rounder
rounder is offline
Originally Posted by jake40ma
Rounder, there are a couple of options. They sell premeasured packs you just drop in during a tire change, or you get the beads , pull out the valve, the beads go into a little bottle they provide. They also give you a tube to connect bottle to valve. The beads tend to clog though, so you can speed the process up by vibrating the valve stem, say with a dremel tool etc... Big difference for me plus you are getting a newly balanced tire with each ride. I advise you to go to the website All this info is there
I went to the website... checked out the how to. Just was not clear on if they removed the valve internals first or does the kit hose that gets screwed on open the air valve enough to install.
Old 01-26-2010, 09:25 AM
HOGRIDA_06's Avatar
HOGRIDA_06
HOGRIDA_06 is offline
You have to remove the valve guts. It's real easy though, you just need to pick up a $4 valve stem tool at your auto parts store.
Old 01-26-2010, 09:30 AM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
I put them in at the last tire change and the ride smooth as silk.
Old 01-26-2010, 10:25 AM
Lakerat's Avatar
Lakerat
Lakerat is offline
Originally Posted by justmejohn44
OK I went to the website. I didn't see anything about 21in rims. Has anyone ran then in a 21in front tire? This is my 100th post Woo Hoo Yay Me!!!
They work just fine in my 21" front wheel.
Just a little tip: When checking your air pressure, make sure the tire is rolled around to the 6 o'clock position or thereabouts. Drained all the air out of my tire once when I did it with the stem at the top and one of the beads was in the valve core.
Old 01-26-2010, 05:35 PM
jake40ma's Avatar
jake40ma
jake40ma is offline
Rounder, the tube is just a plain old length of poly tubing that fits over threads on valve stem and to bottle. When checking tire pressure with beads installed, keep valve stem at 6 o'clock position and give valve one quick shot of air to clean beads from valve area.
paddywagon
03-08-2018 07:48 PM
snuff58
Wheels/Tires
15
06-20-2014 03:22 PM
koolrider101
General Topics/Tech Tips
03-18-2012 02:13 PM
X90
09-10-2011 05:22 PM
Aldamar
Ironhead
05-22-2010 06:46 AM
Quick Reply: Balancing Beads
