Glowing pipes, cant figure this out
Old 07-21-2008, 01:12 PM
grandpawmoses's Avatar
grandpawmoses
grandpawmoses is offline
Default RE: Glowing pipes, cant figure this out
Not sure but I'd bet it takes more than 320 degrees to get the pipes cherry red. Possible exhaust gasket leak at the head could cause the pipe temp to skyrocket.
GPM
&nbsp\\;\\\\\\;
Old 07-21-2008, 01:42 PM
maddghost's Avatar
maddghost
maddghost is offline
My pipes glow red but only if left to idlelike say in traffic.Can't see it during the dy but it's there. Alli'm running mod-wise are Xied's.
Old 07-21-2008, 07:31 PM
SC-Longhair's Avatar
SC-Longhair
SC-Longhair is offline
ORIGINAL: Daehawc
A little background...&nbsp\\;\\\\\\; When installing my AN Big Sucker one night about a month ago I noticed that after a short ride at night the head pipes would glow cherry red.&nbsp\\;\\\\\\; This was with a stock 2008 Street Bob with AN Big Sucker, V&amp\\;\\\\\\;H slip on straight shots, and Nightrider XiED's.&nbsp\\;\\\\\\; Common advice was that it was way lean but some also said it was normal (including Harley).
Did the glow happen before installing your stage 1? If you still have the stock parts try going back then start one piece at a time to narrow down the culprit.
Old 07-21-2008, 07:58 PM
Donny's Avatar
Donny
Donny is offline
When it's really dark, I can see mine glowing, just at the bends. Anyone who has blueing on their pipes, had their pipes glowing at some point, they just didn't notice it.
Old 07-22-2008, 08:47 AM
Daehawc's Avatar
Daehawc
Daehawc is offline
i never noticed it before the a/c but I did go completely back to stock to figure it out and never got it to go away.&nbsp\\; how do i check for an exhaust gasket leak?&nbsp\\; Is that just a simple replacement of the gasket?
Old 07-22-2008, 09:11 AM
glide05's Avatar
glide05
glide05 is offline
pipes glowing at idle is not that uncommon. most fuel management system base maps do not add fuel at 0% throttle.&nbsp\\; if your management system can add fuel at 0%, the glow may go away.
sigtau150
Exhaust System Topics
13
07-31-2013 08:43 PM
eddyp
02-20-2009 05:16 PM
turczytj
01-22-2009 07:33 PM
jamesf0622
02-21-2007 07:22 PM
..but Ill try 2 try
03-06-2006 05:23 PM
Quick Reply: Glowing pipes, cant figure this out
