Rear Axle Removal
Old 07-17-2008 | 03:43 PM
payne149's Avatar
payne149
6th Gear
Default RE: Rear Axle Removal
5lb hammer worked for me after forgetting the idea of trying to protect the axle.
Old 07-17-2008 | 06:35 PM
dyna rider's Avatar
dyna rider
2nd attempt to post- It's out ! I did screw up the axle though. Bent the groove that holds the clip to retain the nut. Have already ordered a new axle.
Old 07-17-2008 | 06:50 PM
JRK5892's Avatar
JRK5892
ahhh see that is why you use the punch! take your time... Do it right do it once brother... it is a pain but it does come out! see about rethreading it and put it on ebay
Old 07-17-2008 | 06:57 PM
dyna rider's Avatar
dyna rider
Joe- I tried the punch trick and it just wasn't enough. I was hitting it so hard I was afraid I was bending the punch. Anyway, I have a plan so it won't happen again. I have some 650 degree teflon grease which I plan to put on the new raw axle. I'm then going to coat it with 1500 degree anti-seize.
Old 07-17-2008 | 07:03 PM
dyna rider's Avatar
dyna rider
Putting on this new wheel is a pain but should be worth it when I'm done. I can't say enough good things about Zanotti motor co. They have the best prices around and great customer service. Thank you all for your help. This has been the most frustrating thing I have done to the bike yet.
lmz5150
EVO
11-04-2018 05:45 AM
ronyd
07-20-2010 03:05 PM
Failz
02-25-2010 09:57 PM
A-10 KChawg
01-04-2009 07:41 PM
eventiller
10-20-2005 04:58 PM
