hate the fxdl headlight, need options?
RE: hate the fxdl headlight, need options?
ORIGINAL: Airborne350G
There is also a light light that some have bought that is cheaper then HD's. It is called a cobra and most get it for around $95. Ebay is a good place to look.
That's the one I have. Bought from easternperformance.com. \\; Recently had an issue with the reflective material behind the bulb coming apart but I called EP and they are making it right.
[IMG]local://upfiles/41150/3CEBE3C11649475999CACDC448057019.jpg[/IMG]
ORIGINAL: 2007fxdc
That's the one I have. Bought from easternperformance.com. \\\\\\; Recently had an issue with the reflective material behind the bulb coming apart but I called EP and they are making it right.
ORIGINAL: rounder
mount come with that?
ORIGINAL: 2007fxdc
That's the one I have. Bought from easternperformance.com. \\;\\\\\\\\\\\\\\; Recently had an issue with the reflective material behind the bulb coming apart but I called EP and they are making it right.
It came with a mount but I ended up keeping the one that came with my 4.5" light I had before.
I had the stock eyebrow headlight and transformed it to a billet lamp assembly. \\; \\; \\; \\;Using the existing modified light assembly I got the attached results. \\; \\;
What I did was remove the indicator light assembly, then the eyebrow/light assembly. \\;\\\\\\;I then used a small band saw to cut off the brow along the molding lines on the back of it. \\;\\\\\\;I then took a half round file to make the curves for the risers. \\;\\\\\\;Did a little finish filing, polishing, and reinstalled the bracket backwards with the same hardware. \\;\\\\\\;I then reinstalled the indicator light assm. (in reverse of course) \\;
I then installed the new billet light assembly I ordered from the HD catalog. \\;\\\\\\;This required drilling a 3/8" hole in the lower triple tree. \\;I used a front motor mount bolt thru to the lamp mounting bracket. \\;\\\\\\;I spliced the wires and hid the connections under the gauge cluster. \\; \\;
Thats it, judge the results for yourself. \\;
Peace,
Garret
Thumbnail Image
Thumbnail Image
Thumbnail Image
Thumbnail Image
Thumbnail Image
Peace,
Garret
Thumbnail Image
Thumbnail Image
Thumbnail Image
Thumbnail Image
Thumbnail Image
I'll take some new shots but here are some aditional shots. \\; Its an easy mod, I did it over a weekend. \\; The eyebrow is aluminum so cutting, filing and polishing is easy.
Peace,
Garret
[IMG]local://upfiles/50404/AE983B1C15C149DB862C0055B48B4F8C.jpg[/IMG]
[IMG]local://upfiles/50404/F54F0FACF9F0468F9BD3034A2155FB86.jpg[/IMG]
[IMG]local://upfiles/50404/E97655E73BB14341A41C6D378A143284.jpg[/IMG]
[IMG]local://upfiles/50404/4BE63301AB1947D4BC84EFA06B9A6B5F.jpg[/IMG]
Peace,
Garret
