Tach Install issue
RE: Tach Install issue
The brace is a SE brace. \\; Course the bolts that came from HD with it were too short, so had to go to Ace Hardware and get the correct length. \\; Bike seems to handle much better in the turns, and the front end seems to much tighter in feeling, rather than a loose/wobble feeling when turning.
I had a tacho fitted to pin 3 ecm on my 2007 dyna superglide custom
i have since fitted a v&H fuelpak and its stopped...V$H say that the tacho wont work as it uses the same signal wire as the fuelpak.
Bet someone has a fuelpak also.
Will the tacho work from the speedo end...if so which wire colour do i tap into Bob
found this when i installed one on my 06 softail. it was really helpful....
http://www.shareaproject.com/pages/p...,p,173,00.html
looneycanuk
07-31-2008 12:36 PM
