Jiffy Stand Hanging
Hello All, I was dragging my jiffy stand in left turns. It just hung down too low, would not retract all the way. I thought it was the spring so I replaced the spring last night, but, I have the same problem. The stand is loose, it doesn't swing back into place, will pretty much stay where I put it. If i hit a bump, it drops down, no tension from the spring it seems, but it has a new spring. So, is there something else I should adjust or change?
I'll check the bolt when I get home. I SHOULD have checked that by default when changing the spring (and this may help with some troubleshooting) but: when I retracted the kickstand, I was able to easily remove the old spring, and it wasn't that stretched! I then put the new spring in, using the coin method. For all I know, the coins weren't even necessary. I'll check the bolt tonight.
