SEII Baffles
RE: SEII Baffles
Mine come out pretty easy when the bike is warm. I take out the bolt with it idleing after a ride &\\; hit the throttle. They either land on the driveway or are at least 1/2 way out. If that does not work stick a broom handle in there, pry up just hard enough to get a grip &\\; pull out. On ocassion th baffle will come out &\\; the packing will stay, I grab the packing with some long needle nose pliers.
RE: SEII Baffles
I went to Home Depot and bought a thin piece of metal rod, a little thicher than a coat hanger, \\;bent it about 1/2" from the end. \\; Then stuck it inside and hooked it on the "spoon" looking piece, clamped a pair of vice grips \\;to the other end and hit it with a hammer a few times and they pop right out. \\; The BCT baffles sound good!!!
RE: SEII Baffles
speaking of baffles, I plan on installing my vance and hines shorts hots this weekend and have 2 options, quite core insert installed (less sound but will they detract from the performance?) or install them without the quite core inserts. whatcha ya'll think..........
also installing VO2 intake - (vance and hines) and a fuel pak.
RE: SEII Baffles
ehc0720 which BCT ones did ya get?
Are the BCT baffles louder, deeper, etc. than the SEII baffles, I ended up just pulling my baffles out cuz i want sound. If I wanted performance I would have gotten the VRSC \\
Wondering what the difference in sound would be from no baffles, and just bending up the lip inside the baffles.
Redbeard, there are 2 bolts that go into each baffle from the bottom to hold em in there on my SEII's. The bolt heads are pretty obvious on mine. I wonder if they just stuffed them in there and forgot to replace the bolts on yours.
I'm curious too abut those BCT baffles also, I know they sound good from what I heard but I want to know about the performance gains (according to their website). Also wondering about a remap if you use those suckers.
Biggron keep us posted, definitely want to know how those things sound.
