Stock SB bars to dragbars with 6" risers ?
just need to know if i need to change the cables .
on going from Stock Streetbob bars to drag bars with 6 inch risers .
I have heard it will work but just wanted some back up on that from the experts here .
thanks for any info
later
Slinger
thanks for any info
later
Slinger
RE: Stock SB bars to dragbars with 6"\\\\\\\\\\\\\\; risers ?
I did four inch risers with the stock mini apes, so I would have to say no cables or wiring needed. I changed nothing, I did run the clutch cable in front of the bars instead of behind, it looked better and gave me more clearance when turning bars all the way to the left. I also bent the brake line a little beneath the tripple tree to give me a couple inches, the throttle and idle cables needed to be bent (Carefully!!!) under the grip to point more straight down.
If i did four inch risers with the mini apes, you should be fine......
