Oil change how often?
Old 04-10-2017, 07:45 AM
Tall Timber's Avatar
Tall Timber
Tall Timber is offline
Originally Posted by TinCupChalice
Heh...
Ok, so I posted in a zombie thread
lol I didn't notice either
  #32
Old 04-10-2017, 08:39 AM
HKMark23's Avatar
HKMark23
HKMark23 is offline
Received 1,940 Likes on 1,116 Posts
Absolutely! And permanent oil filters? Love 'em
Did you get your 3Guyz oil filter relocation done yet? That's another full win; I spent a bunch of time last week and over the weekend tweaking mine and replacing hoses.
Those images you seek of my front forks will be posted within a day or so now that I'm happy with my relocation plumbing
The 3G oil relocation kit is in hand but I won't be installing it till my next oil change, (in about 3000 mi ). ,,,,,,,,,,,,,,,,,,,,,,,,,, edited out ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
I'm taking my jiffy stand off today. I'll take it to a machine shop up the road to get it drilled. Waaay too hard for my little 3/8 drill.
Sorry for the hijack .
TinCupChalice (04-10-2017)
  #33
Old 04-10-2017, 09:13 AM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,751 Likes on 3,962 Posts
****** edited per HKMark23 *******
Smooth! Very well done
I figured with me wanting to alter fluid level and spacer lengths it would be just as easy to pull off the wheel and remove the forks for an accurate fluid measurement; I should have it back together later this afternoon.
Once the forks and wheel is back on I'll lower the bike and put a 2x4 under the Jiffy and find out just how tough that critter is
  #34
Old 04-11-2017, 05:08 PM
HKMark23's Avatar
HKMark23
HKMark23 is offline
,,,,,I figured with me wanting to alter fluid level and spacer lengths it would be just as easy to pull off the wheel and remove the forks ,,,,
Glad to hear you're using that method. I'm editing my post # 32 so no one will read it and follow what I did.
It occurred to me some time after I posted #32 that MY forks are different. They aren't stock. I had done another mod prior to this one and my pre-load is much less than stock. When you're dealing with significant pre-load it is better and safer to remove the forks before working on them.
TinCupChalice (04-12-2017)
  #35
Old 04-11-2017, 06:16 PM
NORTY FLATZ's Avatar
NORTY FLATZ
NORTY FLATZ is offline
Received 5,742 Likes on 3,105 Posts
Regardless of what OCI you adhere to, use a quality lubricant.
EDIT~Doesn't matter what year it is.
Last edited by NORTY FLATZ; 04-11-2017 at 06:19 PM. Reason: didn't know this thread is old enough to be in the 4th grade!
  #36
Old 04-12-2017, 06:11 AM
TinCupChalice
I edited my quote of your post; you're exactly right! My front forks are also setup up with much less pre-load and I could have done as you suggested quite easily, I modded my front forks early on and fork cap removal is a simple no drama job with my pre-load. You're correct, with the OEM setup the spring pre-load is going to cause a real surprise if the tubes are on the bike when you remove that fork cap
Still was a great idea, though; but only with aftermarket fork internals
HKMark23 (04-12-2017)
  #37
Old 04-12-2017, 07:37 AM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
Whenever the oil light comes on. That's what it's for, right?
  #38
Old 04-13-2017, 04:31 PM
Simbo's Avatar
Simbo
Simbo is offline
Oil? What's Oil?
  #39
Old 04-13-2017, 05:19 PM
emperor wurm's Avatar
emperor wurm
emperor wurm is offline
what is the best oil to use?
  #40
Old 04-13-2017, 05:39 PM
saltlick's Avatar
saltlick
saltlick is offline
i have been changing mine every year in May since it sits in my garage all winter without running. Figured its collecting water and dust and prob just a good idea. Im starting to rethink that though. ***** getting so expensive with the full synthetic its a good $40 oil change with a filter and thatch with me doing it. Im starting to think i should just change it depending on how many miles i put on it.
Quick Reply: Oil change how often?
