fuelpak
Old 07-04-2008, 09:22 PM
firestop52's Avatar
firestop52
firestop52 is offline
Default fuelpak
I have an 06 Street Bob S E stage 1 air filter, V&amp\\;H big radius pipes. Installed fulpak and now bike feels like it falls on its face when I shut the throttle. Fuelpak site says to raise value on #23. Mine is 16 now. Has anyone raised this value, what did you find that worked? Thanks for any help.
&nbsp\\;
[IMG]local://upfiles/41831/838AD542E00B4B86BDFD602131580ED3.jpg[/IMG]
Old 07-04-2008, 09:29 PM
BluBob's Avatar
BluBob
BluBob is offline
Default RE: fuelpak
I think dudes were bumping that mode up to 50.&nbsp\\; Do a search and see what you find.
Old 07-04-2008, 09:34 PM
yellowted's Avatar
yellowted
yellowted is offline
Default RE: fuelpak
they had me raise mine from 15 to 16.&nbsp\\; i have an 07 dyna se with vance and hines slip-ons.&nbsp\\; i sent them an email because of popping a bit too much.&nbsp\\; i noticed no change but the other day after a 5 mile casual ride while lumping around the corner at 5 mph it just shut off, not stall.&nbsp\\; just yesterday i rolled it back to 15.
Old 07-05-2008, 12:44 AM
Donny's Avatar
Donny
Donny is offline
Default RE: fuelpak
from what I understand, mode 23 at 16 shuts off or reduces fuel to the injectors. It can definately be annoying. If you change it to 50, it doesn't get that dead feeling anymore, but mine backfires and pops at that setting. Only way to know, is try it!
Also, I was told to re-synch the throttle (mode 19 if I remember) any time you change a setting.
Old 07-05-2008, 06:45 AM
tramp's Avatar
tramp
tramp is offline
Default RE: fuelpak
what is a fuelpak?
Old 07-05-2008, 08:01 AM
jluvs2ride's Avatar
jluvs2ride
jluvs2ride is offline
Location: Back in the Good Ole USA. South Carolina to be exact.
Default RE: fuelpak
Seems like mode 23 is the answer to all problems.
Old 07-05-2008, 09:46 AM
firestop52's Avatar
firestop52
Default RE: fuelpak
Thanks for all the help, I did find a great thread in the tech forums that had a lot of info about the setting on #23. It does seem that #23 is the answer to just about all problems, we will see.
Tramp, fuelpak is made for V&amp\\;H to hook up in line with your bikes computer to compensate for the bike running lean due to high flow air filters and pipes.
Old 07-05-2008, 10:27 AM
xmarine's Avatar
xmarine
xmarine is offline
Default RE: fuelpak
firestop
up #23 to a setting of 50. Re-calibrate #19 EVERY TIME. I found that rolling on and off as fast
as I could in #19 cured the popping for me. For what it's worth, V&amp\\;H tech said do it slowly but
it didn't work for me. Rolling off quickly solved it for me.
xmarine
Old 07-05-2008, 10:44 AM
flynavy's Avatar
flynavy
flynavy is offline
Default RE: fuelpak
Get IED's - no more pops, backfires, and/or falling dead on it's face at decel.
&nbsp\\;
nightrider.com
Old 07-05-2008, 12:37 PM
tramp's Avatar
tramp
tramp is offline
Default RE: fuelpak
ORIGINAL: firestop52
Tramp, fuelpak is made for V&amp\\;\\\\\\;H to hook up in line with your bikes computer to compensate for the bike running lean due to high flow air filters and pipes.
&nbsp\\;
thanks, you learn something new everyday
Quick Reply: fuelpak
