Cutting the windshield how to HELP
Old 07-04-2008, 11:00 AM
bikecop40's Avatar
bikecop40
bikecop40 is offline
Default Cutting the windshield how to HELP
&nbsp\\; I just installed a set of auxiliary running lights on my 07 FXD , now I need to cut the windshield a little at the bottom sides to make the job complete.
&nbsp\\; Question is what is the best way to cut the windshield&nbsp\\;
&nbsp\\;&nbsp\\; I will post pics of before, during and after when complete!
&nbsp\\; Thanks for all the input
D/C
Old 07-04-2008, 11:25 AM
hockey8787's Avatar
hockey8787
hockey8787 is offline
Default RE: Cutting the windshield how to HELP
i used a dremel works pretty well
Old 07-04-2008, 11:33 AM
JoeFLHX's Avatar
JoeFLHX
JoeFLHX is offline
I had mine cut at a glass shop and they used a rotary drill type cutter. I just did not trust myself, but 100s of guys have cut there own. Good to put blue tape over the cut lines. I have read about guys who use a coping saw. You can sand the edges, a quick swipe with MEK on a rag will make the edge like factory.
Old 07-04-2008, 12:05 PM
bikecop40's Avatar
bikecop40
Thanks for the info....................... I think a dremel tool will do the trick&nbsp\\; and I will post pics for the forums
&nbsp\\;&nbsp\\; D/C
Old 07-04-2008, 01:13 PM
Frankster69's Avatar
Frankster69
Frankster69 is offline
Use the dremel but put masking tape on it first make your lines then cut it . The masking tape will keep it from cracking. Pretty easy to do just take your time.
Old 07-04-2008, 01:39 PM
HD7585's Avatar
HD7585
HD7585 is offline
What is MEK?
ORIGINAL: JoeFLSTC
Old 07-04-2008, 01:55 PM
Airborne350G's Avatar
Airborne350G
Airborne350G is offline
MEK =methyl ethyl ketone and it is a solvent,,
phillaf65
08-20-2023 09:03 AM
joshuaro
10-12-2010 01:48 PM
patrol557
06-27-2008 07:36 PM
Nellybelle
06-10-2008 10:24 AM
UCRED
06-06-2008 04:00 PM
Quick Reply: Cutting the windshield how to HELP
