installing Kuryakyn grips
RE: installing Kuryakyn grips
Watch carefully how the old one comes off and reverse the process with the new one. I discovered when I reajusted the cables that the throttle was only opening up to about 3/4. So the factory isn't perfect either.
A trick for the left grip is to remove the butt plate before glueing and installing so it doesn't build back pressure. Slide the grip on fast as the glue drys quickly. Note the hand position before you install the grip. I found
the ISO grips to be very comfortable. Good luck lowrider.
Thanx for all your help, I installed the grips &\\; the throttle side was'nt as difficult as I thought it would be, &\\; the left side was even easier, but I have a major issue......BIKE WON'T START!! NO ENGINE LIGHT, DON'T HEAR THE FUEL PUMP. ONLY THE LIGHTS GO ON WITH INGINTION KEY!! HELP! it's a holiday &\\; dealers are closed.
1 Post
[quote]ORIGINAL: Steve Zodiac
 \\;I once saw a guy pull \\;an old Triumph onto the centre stand and both the grips came off in his hand. The bike fell over and he stood there with a blank look on his face holding the grips. It was pretty funny.
I would have liked to of been there when that happend. \\;lol
45js45
11-19-2012 08:41 PM
