rev limiter
Old 07-01-2008 | 08:46 PM
hockey8787's Avatar
hockey8787
Default rev limiter
ok guys whats up with my 07' wide glide i've only had it since january and i have been babying her until tonight i want to see what she would so i went thru the gears and about 3/4 throttle it started to break up in every gear is this the norm i assume this is the rev limiter&nbsp\\; am i wrong WTF
Old 07-01-2008 | 08:52 PM
Phlipper's Avatar
Phlipper
Default RE: rev limiter
Yep.&nbsp\\; Sounds liKe sheeyite when you hit it.&nbsp\\; The flash update ECM will increase the revs to six thousand sump'n.&nbsp\\; Way mo bettah. [8D]
Old 07-01-2008 | 08:57 PM
dyna rider's Avatar
dyna rider
The stock rev limit is 5500 rpm. It's like hitting a wall just when you are starting to pick up real power.
Old 07-01-2008 | 08:58 PM
hockey8787's Avatar
hockey8787
phlipper what is it set for now stock
Old 07-01-2008 | 09:00 PM
hockey8787's Avatar
hockey8787
sounds like **** it sucks so&nbsp\\;i cant use all of the power i payed for
Old 07-01-2008 | 09:14 PM
dyna rider's Avatar
dyna rider
Is it a fi or a carb bike ? What engine mods have you done ? If a fi bike what kind of fuel management have you got ?
Old 07-01-2008 | 09:21 PM
hockey8787's Avatar
hockey8787
Dyna it's stock only mod's are rush slip-ons 2" fi
Old 07-02-2008 | 02:15 AM
SK8ROD's Avatar
SK8ROD
you can get the dealer to program "rev extend" which takes you to 6250, but if you go for a PCIII you can enable it yourself plus get a better fuel map etc plus get covered for any further mods you do..&nbsp\\; getting these bikes to rev out more does make a huge diff i have an 08 Bob and can get it off the clock no problem..&nbsp\\;
Old 07-02-2008 | 04:05 AM
Gaffy52's Avatar
Gaffy52
Hey Pete - where did you get the smoked tail light?
Old 07-02-2008 | 06:42 AM
dyna rider's Avatar
dyna rider
Sounds like a problem with the ecm. Needs to go back to the dealer for him to evaluate and fix. It should rev just fine all the way to the limiter with full throttle. Keep us posted on what the dealer does for you.
Quick Reply: rev limiter
