rev limiter
Old 07-02-2008 | 11:45 AM
hockey8787's Avatar
hockey8787
Default RE: rev limiter
just left the stealer and they say it's normal i say b/s but they wont do any tuning unless i pay for it only has 1600 miles **** this blows
Old 07-02-2008 | 12:28 PM
SK8ROD's Avatar
SK8ROD
ok,, seriously, forget the dealer and go for a PCIII, it makes a big diff and you get your new rev limit plus its a lot of fun tuning the maps...
Old 07-02-2008 | 01:56 PM
Phlipper's Avatar
Phlipper
ORIGINAL: hockey8787
phlipper what is it set for now stock
I believe stock is 5500 rpm.&nbsp\\;I hit it on mine a few times after the 1000 mile service when out seeing what the new motors would do.&nbsp\\;It sounds very nasty.&nbsp\\; You don't have a problem ... you're just hitting the rev limiter.
You can get the Stage 1 ECM flash for $150 to your box that richens up the mixture a hair (a good thing) and also sets the rev limiter to 6300, if I remember correctly.&nbsp\\;If you're not going to do any work to the engine (cam, porting, boring/bigger pistons, etc) the Stage 1 ECM flash is all you need.&nbsp\\; Don't spend money for the aftermarket fuel devices if you're just going with bigger pipes and air cleaner.
Old 07-02-2008 | 02:10 PM
nvsteve's Avatar
nvsteve
I don't think you're hitting the rev limiter.&nbsp\\; Not at 3/4 throttle in "every gear".
Something else is going on.&nbsp\\; Could be something as simple as a bad spark plug.
Old 07-02-2008 | 02:43 PM
Dyna_Soar's Avatar
Dyna_Soar
So why would they put in a rev limiter of 5500 if the&nbsp\\;engine can take 6250 in the first place? I can see them raising the limit if there was some sort of mechanical change to the engine. But if there are no other changes, why is HD limiting the engine to 5500 stock?
Old 07-02-2008 | 10:00 PM
hockey8787's Avatar
hockey8787
guess i need to talk to someone else&nbsp\\;the one i talked said i have to dyno it but you guys seem to know more than he did sk8rod how much does that pcIII cost
Old 07-02-2008 | 10:15 PM
efciv's Avatar
efciv
Go to http://www.fuelmotousa.com&nbsp\\;for your PCIII.
Surly
07-09-2019 11:22 AM
rome304
07-11-2009 07:36 AM
ggibson
12-21-2008 01:13 PM
hogdad
06-13-2007 08:09 PM
Coyote72
06-19-2006 11:20 PM
Quick Reply: rev limiter
