Pipe suggestions?
RE: Pipe suggestions?
depends if you want sound id go either back with samsons, mail back the pipe and they will prob give ya a new one or go to jirehcycle.com and pick up a set of their big growls (super cheap)also made by samson cheap but if you want performance you have to go D&\\;D better than thunderheader and Rinehards, to many guys have those on their rides. just FYI.
I had the same setup I see on yout scooter. \\; Using the existing modified light assembly I got the attached results. \\;
What I did was remove the indicator assembly, then the eyebrow/light assembly. \\; I them used a small band saw to cut off the brow along the molding lines on the back. \\; I them took a half round file to make the curves for the risers. \\; Did a little finish filing, polishing, and reinstalled the bracket backwards with the same hardware. \\; I then reinstalled the indicator light assm. (in reverse of course) \\;
I then installed the new billet light assembly I ordered from the HD catalog. \\; This required drilling a 3/8" hole in the lower triple tree. \\; I used a front motor mount bolt thru to the lamp mounting bracket. \\; I spliced the wires and hid the connections under the gauge cluster. \\;
Thats it, judge the results for yourself.
Peace,
Garret
[IMG]local://upfiles/50404/2261B65F4F8A4BCFAA312B0243988613.jpg[/IMG]
[IMG]local://upfiles/50404/B9F84363EE1D4611B71FB9A0EA0FD0DB.jpg[/IMG]
[IMG]local://upfiles/50404/C2F93203631B407CB2832CF604106011.jpg[/IMG]
[IMG]local://upfiles/50404/BE4489095BC9456685A87F7D37ABA2B1.jpg[/IMG]
[IMG]local://upfiles/50404/D2206D2976C1466F802EECB903145D23.jpg[/IMG]
Peace,
Garret
ORIGINAL: PotterBoy
My front head pipe broke today so i am looking for a new set of pipes. \\;\\\\\\; I had a pair of sampson streer sweepers which i really liked. \\;\\\\\\; What do you guys recommend?
[IMG]local://upfiles/65427/327355FF131C48FD920557D7FDFB3BBE.jpg[/IMG]
