Rolling On - 06 DYNA Bearing Question
Hello all. Need your help. \\;My inner primary bearing fell apart at less than 5K miles on my 06 FXD35 which is out of warranty. The dealer replaced it with a "High Torque Bearing", P/N 1110-0018. \\;The OEM bearing (at least the inner race) \\;was P/N 34091-06. \\; $300 later....
H-D Customer Service says they would have 'helped me out" if I had installed an OEM part. Need to find an angle to dispute that. \\;My H-D service advisor said that they would have replaced the bearing with the same P/N (34091-06) that was originally installed. \\;Can any of you confirm that? If so, the basis of my argument will be that I do not want another defective bearing installed and at the least they should reimburse me for the labor (about $260).
Thank you!
Thank you!
Babe
09-01-2008 01:36 PM
