Need front end CLUNK service bullitin
#31
RE: Need front end CLUNK service bullitin
I posted on this a week or so ago, but not to many people read it. I had the clunk on my '08 with only 56 miles on it. Knew what it was and the bulletin number thanks to this site. The dealer at first didn't want to do it cause my VIN didn't list it as needed. I eventually talked them into the work and they did fall away checks. This is something you need to do if you replace the washer yourself.
There was another guy in the dealership that had had the same issue since new and like a few of you, his dealer told him that it was normal for harleys. Well, two riding seasons into owning the bike and the nut had loosened enough that the neck could be move by hand. If you had buddies or just overhear someone mention this infamous "CLUNK" let them know what it's all about. I'd hate to get on here on day and see that someone got killed because there neck seperated.
#32
It is funny you all are mentioning this clunk becuase. \\;\\\\\\; I have noticed that when I brake and also hit a bump or pothole my '07 makes a clunking noise, too.  \\;\\\\\\;At first I thought it was the transmission downshifting on its own - that's what it sounds like, as if from the xmission is located, not the stem nut area.
#34
I removed the chrome stem cap just to see what everybody was talking about. What HD calls the lockwasher is nothing more that a flat washer with a tab bent up against the flat of the nut. Not sure what they were thinking when they designed that, because the so called lockwasher is not going to hold anything. That and the nut are just going to loosen up together. I would rather see a regular spring lockwasher \\;on there instead. Mine was still tight yet, but I will run it into the dealer with a copy of the \\;bulletin and have them fix it. \\;
#35
#37
ORIGINAL: harley_jeff
It is funny you all are mentioning this clunk becuase. \\; I have noticed that when I brake and also hit a bump or pothole my '07 makes a clunking noise, too. \\; At first I thought it was the transmission downshifting on its own - that's what it sounds like, as if from the xmission is located, not the stem nut area.
There is a rubber stopper attached to the frame but the pad area easily spins out of the way allowing the jiffy stand to make contact with the frame. \\; It gives you the sound of a clunk you can even feel up through the pegs if it's slapping hard enough and making good contact with the frame.
This solved a little bit of my noise/clunk feel, but the front-end clunk was entirely different because it was accompanied by the feeling of front end looseness, and the sound was a little bit different in pitch, like it was muffled. \\; Which makes sense since the clunk was happening under a cap in the steering head.
#38
#39
I am glad to see this bulletin. I have an 06 wide glide that clunks and feels so loose in the front end I feel like I am riding on ice. When you pull in the clutch the hole front end vibrates badly. I have been fighting with the dealer for some time now always ending with nothing being done. I made an appointment with another dealer and will be armed with this bulletin. Thankyou for posting.
#40
ORIGINAL: LWOS
 \\;\\\\\\; Hey Don 51
....................Let us know what your Dealer says, and if they have to order parts or what. \\;\\\\\\; Have him explain what they exactly do and report back \\;\\\\\\; to this thread for the rest of us would ya???
You got it!!! I read from some others that the original lock nut is replaced by a thicker flat washer. I still don't see how that will be any different!!! If that's what it is, then I just might go with a regular spring lock washer, unless someone convinces me that wouldn't work. I'll see what the local HD dealer says....so far they have been pretty good with me.
