detachable windshield headlight problem
Old 06-19-2008 | 10:42 PM
DoubleU's Avatar
DoubleU
Default RE: detachable windshield headlight problem
I've got the same issue.&nbsp\\; Can't even use the high beam at night.&nbsp\\; Way to much reflection coming back at me.&nbsp\\; Putting the shield all the way to the top of the trees does away with it, but I get a lot more wind "pulsing" when it's up that high.&nbsp\\; I thought it was supposed to rest against the bottom of the trees.
&nbsp\\;
Dub
Old 06-19-2008 | 11:25 PM
Biker Bob's Avatar
Biker Bob
ORIGINAL: maddghost
if you loosen the bottom bolts you can adjst the angle of your windshield a little bit,and make sure you slide the shield all the way up! Incidentally i think&nbsp\\;\\\\\\;nobody should&nbsp\\;\\\\\\; have&nbsp\\;\\\\\\; the slightest problem for the&nbsp\\;\\\\\\;bucks kind of bucks we shell out&nbsp\\;\\\\\\;for&nbsp\\;\\\\\\;our&nbsp\\;\\\ \\\;equippment!
&nbsp\\;
Dude, +1
&nbsp\\;
Old 06-19-2008 | 11:43 PM
harleridr's Avatar
harleridr
Hi All,
&nbsp\\;Just a thought, I used the frenched headlight rim it also cuts down on the side glare.
fred
Old 06-19-2008 | 11:54 PM
Upnorth's Avatar
Upnorth
I just took delivery on a 2008 FXDC and have the exact same problem! The glare is unbelievable when the high beams are on and it is unsafe!. The dealer told me when he delivered it that I better order some trim rings, but the whole concept of the adjustable height windshield is to be able to adjust it to the height which allows the least buffeting for the rider and doesn't obstruct vision. As a retired senior sales and marketing executive I think some companies executives should get off their lazy a** es and actually test out some of these products they sell for over $800! They are giving "suits" a bad name . I love my FXDC but the accessories are not up to snuff.
Old 06-19-2008 | 11:56 PM
Upnorth's Avatar
Upnorth
Old 06-20-2008 | 12:10 AM
LownBlue's Avatar
LownBlue
I too went the visor to the headlight route. It worked like a champ and looks good too.
Old 06-20-2008 | 12:35 AM
LWOS's Avatar
LWOS
I've got the Trim rings as well.........and it eliminated the problem. It's listed as the Visor Style headlight trim ring part number 69735-05 and it cost $33.95.&nbsp\\; I also purchased&nbsp\\;a set of the&nbsp\\;" Turn Signal Bullett style visor kits for the front and rear signals....to give it a matched look. Those sell for $32.95 each. part number 69760-05 for the front and 69761-05 for the rear signals.
Old 06-20-2008 | 07:39 AM
Tony P's Avatar
Tony P
I to have the visor. I also bought a headlight extension that&nbsp\\;I haven't installed yet. It cost about $25, and if it works, it will&nbsp\\;be alot cheaper than replacing the entire headlight assembly.
Old 06-20-2008 | 02:28 PM
mart73's Avatar
mart73
I have an 08 FXDL and I'm not having that problem. I have the essentials kit too.&nbsp\\;My windshield sits about a 1/2 above my headlight and there is maybe 3/4" gap between the HL and the WS. I haven't noticed the glare at all.
ShrinerRider
05-21-2020 02:43 PM
bonechief
03-21-2010 09:32 PM
LWOS
06-17-2008 12:20 PM
cadillac
01-28-2008 12:08 AM
warren888
05-22-2007 11:53 AM
Quick Reply: detachable windshield headlight problem
