Do throwover bags NEED a bracket?
Old 06-19-2008, 08:27 PM
SPECIAL ED's Avatar
SPECIAL ED
SPECIAL ED is offline
Default RE: Do throwover bags NEED a bracket?
The short answer is no you do not need support brackets But.... they will eventually damage your paint somewhere or will be damaged from the brake disk.Mine destroyed the paint on my back fender and wore through the paint on my belt guard.If you're the type of person that's real particular about your paint job I would recomend the support brackets or getting something like Easy Brackets.
Old 06-19-2008, 08:35 PM
bryanownzu's Avatar
bryanownzu
bryanownzu is offline
HDdave are your bags compact slant or standard?
Old 06-19-2008, 09:15 PM
hddave2's Avatar
hddave2
hddave2 is offline
they are slanted bags and they have not hurt the paint or the belt guard. i had real good luck with themnn no brackets needed with the bags i have
Old 06-19-2008, 09:21 PM
simsjam's Avatar
simsjam
simsjam is offline
No problems with small bags BUUUUT better safe than sorry. If you are on the road and they get wrapped up in your back wheel it can lock up and instant death. I read a thread about this happening to some one while riding on the interstate in a group and they all watched him die.
Old 06-19-2008, 09:25 PM
bryanownzu's Avatar
bryanownzu
hddave are they the compact or the standard size though?
Old 06-19-2008, 10:01 PM
jbphoto's Avatar
jbphoto
jbphoto is offline
ORIGINAL: rounder
ORIGINAL: jbphoto
I can't speak for all bikes or all bags but I mounted Willie and Max Ranger bags on my Bob with no support bracket.&nbsp\\;\\\\\\\\\\\\\\;
do they flop around at all?
Nope, they're solid as a rock.&nbsp\\; They're tied to the top and bottom of the shock and the back is tied to a bungee nut installed where the rear sigs used to be.
Old 06-19-2008, 10:09 PM
hddave2's Avatar
hddave2
hddave2 is offline
i guess they would be standard size the fit perfect between the rear sigs and the shocks
Old 06-19-2008, 10:10 PM
rayfinseats's Avatar
rayfinseats
rayfinseats is offline
The short answer is no you do not need support brackets But.... they will eventually damage your paint somewhere or will be damaged from the brake disk.Mine destroyed the paint on my back fender and wore through the paint on my belt guard.If you're the type of person that's real particular about your paint job I would recomend the support brackets or getting something like Easy Brackets. "
I agree. I made my own because they didn't make them when I bought my bike. Now they sell them for like $150. I used a 1/8"&nbsp\\;\\\\\\;X 2" angle iron&nbsp\\;\\\\\\;with a 1 1/8" hole in it and slipped that between the chrome and fender and used 3/8" steel rod to bend and weld to that. They rubbed on my shocks before I added a rubber snubber cuz they were off a bit. Careful measurements.
&nbsp\\;
Old 06-19-2008, 10:31 PM
mp's Avatar
mp
mp is offline
My experience is, you're a lot better off with supports.&nbsp\\; And you can find them a lot cheaper than $150.
Old 06-20-2008, 06:12 AM
hddave2's Avatar
hddave2
hddave2 is offline
ORIGINAL: bryanownzu
the bags i have are about 12'x 9'x 5.5' willie and max bags
Quick Reply: Do throwover bags NEED a bracket?
