Black fender struts
Old 06-16-2008, 08:52 PM
firestop52's Avatar
firestop52
firestop52 is offline
Default Black fender struts
Can I buy black fender struts? Trying to avoid too much down time. Or will I have to wait till winter and powder coat mine.
Old 06-16-2008, 09:18 PM
subculture08's Avatar
subculture08
subculture08 is offline
Default RE: Black fender struts
HD stopped the black strut covers when they did away with the sport.
Dark Custom really means - we have to powder coat HD chrome.
Keep an eye out for a set from someone who upgrades to chrome, that is what I did. Then sold mine after the swap.
Old 06-16-2008, 09:19 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
down time? just un bolt them and run your bolts right back in, your fender rails on the on the outside on a dyna... when you get them put them back on, 5 min job both sides
Old 06-16-2008, 09:27 PM
firestop52's Avatar
firestop52
JRK5892, Are you saying that I can run without them?
Old 06-16-2008, 09:46 PM
subculture08
ORIGINAL: firestop52
Joe is correct you can.
I could not since I have quick detach setup. They need to contact the covers to line up properly.
hd_sob's Avatar
hd_sob
hd_sob is offline
ORIGINAL: JRK5892
Don't forget, the shocks also have to be unbolted and that can be tricky unless you have a lift or some help...
Old 06-16-2008, 09:48 PM
firestop52's Avatar
firestop52
I didn't think I could go without them, Thanks a lot for the help!
Old 06-17-2008, 06:20 AM
Bassman's Avatar
Bassman
Bassman is offline
When I pulled mine off to powdercoat them, I had to stop and really think about if I wanted to put them back on at all. I liked the way it looked without them
Old 06-17-2008, 01:33 PM
hk_shooter's Avatar
hk_shooter
hk_shooter is offline
ORIGINAL: Bassman
&nbsp\\;
That's the stage I'm at now.
Except the rear turn signals look funky without the covers and their 'dimples' for the signals.....
Old 06-17-2008, 02:53 PM
shimmon's Avatar
shimmon
shimmon is offline
buy someones take offs on ebay, have them coated and then swap when they get back from powder.&nbsp\\; thats what i plan to do.
Quick Reply: Black fender struts
