Installing HD rear turn signal relocation kit
1 Post
RE: Installing HD rear turn signal relocation kit
ORIGINAL: dlwilson72
I"m installing the HD rear turn signal relocation kit to make room for bags and a solo rack on my FXD. \\;\\\\\\; Anyone know any tricks or have any advice on the install.
Do not over-tighten them, they will break easily.....
Get some heat-shrink insulation tube (Home Depot). To get the turn signal wires into the bar, I had to strip the outermost insulation\\; I then slipped the heat shrink tubing over the threaded wires to replace the layer or protection and neaten things up.
When the directions say "Cut existing wire plug in's as short as possible" DON'T
Leave enuff that you can solder the wire back together at the module.
If you don't get them squeezed perfectly, they will not go in the connector.
My 2 hr. job \\; ended \\; up being \\; 4 \\; plus.
Good luck
Kim
Good luck
Kim
bdn56
01-02-2008 09:29 AM
madmustang4
09-21-2006 09:13 PM
