Big shot staggered 02 holes and PCIII
I,m installing a PCIII , a Screaming Eagle ac kit and some Vance and Hines big shot staggered pipes .
Question is should I take out my 02 sensors and reinstall them in the Vance and Hines pipes or just plug the holes ?
The PCIII has the 02 eliminators .
Also any good pics or advice on installing the PCIII as to location and or electrical grease or ??
I tried to search , but I,m unable to get any pics .
I have a 2007 LOW RIDER ,,, Thanks....
RE: Big shot staggered 02 holes and PCIII
Plug the holes on the new pipes, leave the sensors in the stock pipes in case you need to put them back on (noise regs., etc.)
Not sure of the plug size or thread, but you could take the pipe to an auto parts store and they can match it up with plugs.
 \\; \\; \\; 1.5 x 18 is the plug size. I guess an oil pan drain plug will work. I bought chrome plugs from eastern performance. I put my PClll under the electrical box, used dielectric grease on all connections, and leave the USB cable plugged in and tucked away. For good directions on setting the throttle position search a forum member "iclick". He has some great info and help.
i installed my PCIII vertically between the battery and the ecm. \\; you can pull it up and lay it on top when adjusting your map or what not. \\; i \\;dont have security so i had a bit more room. \\; just take your time and you'll do just fine.
here is a \\;link i found helpfull...
https://www.hdforums.com/m_2445677/m...tm.htm#2445677
