Vibration free. Front isolator problem fixed.Pics
Old 06-30-2008, 03:58 PM
expy's Avatar
expy
expy is offline
Default RE: Vibration free. Front isolator problem fixed.Pics
Good to hear SeeNoSun. Thanks for your input on this thread.
  #122
Old 06-30-2008, 04:40 PM
0ut1aw's Avatar
0ut1aw
0ut1aw is offline
I stumbled across this same problem when I accidentally stripped one of the bolts in my front isolator.
&nbsp\\;
My old and new where very different and the vibrations are better with the new one.&nbsp\\; It also has helped a great deal to allign the engine every so often.
&nbsp\\;
&nbsp\\;
  #123
Old 07-04-2008, 01:19 PM
ackman1968's Avatar
ackman1968
ackman1968 is offline
I just did mine yeasterday and there is a difference. Most noticably in the pegs. It never bothered me but maybe now my wife can enjoy the ride a little more. I think if they went with a little stiffer rubber it would help them last longer.
  #124
Old 07-04-2008, 07:09 PM
dynaglider's Avatar
dynaglider
dynaglider is offline
ORIGINAL: ackman1968
I I think if they went with a little stiffer rubber it would help them last longer.
I believe you are right that they could be made to last longer. But stiffer rubber also would do a poorer job of isolating the vibes that you are so sensitive to.
It's a real world trade-off: longer part life results in poorer performance, but the better performing part fails too soon. What are you going to do?
  #125
Old 07-13-2008, 09:07 PM
SeeNoSun's Avatar
SeeNoSun
SeeNoSun is offline
Well its back. I put almost 1000 miles on the new front motor mount. I just got back from Gettysburg Bike Week. I put about 200 miles a day on each day and my bike was running great. On the way home after about 20 miles I felt something change or loosen up and the vibration was back. This sucks. I can't believe the front motor mount would fail within 1000 miles of being replaced.
I'll call the dealer tuesday and see what they have to say. The guy who works on my bike is great. Hopefully he can figure it out.
  #126
Old 07-13-2008, 11:41 PM
Dynaflyer's Avatar
Dynaflyer
Dynaflyer is offline
I've Noticed strong buzzing and Vibration in the pegs between 1900 up thru 2300 RPM's
Goes away after that. Anyone had these symptoms? Isolator Bad?
  #127
Old 07-14-2008, 05:28 AM
dynaglider's Avatar
dynaglider
ORIGINAL: Dynaflyer
Service manual says check for cracks or tears in mount rubber, check stabilizer for wear, check mount bolts are tight, check mount rivets are not sheared, and check that mounts support weight of motor. There are two isolators front and rear under the motor and the stabilizer at the top. With all the weight and vibration in these motors, performance will change over time with wear and shifting. Vibration in a certain range that goes away sounds normal and to be expected.
  #128
Old 07-15-2008, 03:20 PM
Slacker8's Avatar
Slacker8
Slacker8 is offline
Thanks expy.
I got my new 08 Bob about 2 weeks ago and noticed the vibration on the second ride. I'm taking it to the dealership today and hopefully I won't get the "it's a dyna excuse". Got to get home first to check the isolator to see if it is actually the problem. I'm still going to have the local service department check it over even if it appears to have the necessary gap. I'll post as soon as I have some more info....
  #129
Old 07-15-2008, 03:58 PM
sofus's Avatar
sofus
sofus is offline
I have some 6 k miles on my '08 Street Bob. It vibrates...&nbsp\\;exactly the same way as it did when I picked it up.&nbsp\\;No more, no less. Maybe I've been lucky. &nbsp\\;&nbsp\\;
  #130
Old 07-15-2008, 07:07 PM
Slacker8's Avatar
Slacker8
Slacker8 is offline
Dynaglider this is my first Harley. I did have a friend(regular Harley rider)&nbsp\\;ride it and he also noticed it. I spoke with another friend and he also said it should not vibrate at all, isn't that the reason for the isolators?
&nbsp\\;
My riding experience (10+ years)&nbsp\\;is mostly on rice burners (no crotch rockets) and some dirt bikes. I understand that Harley's "vibrate" but you can tell when a vibration isn't right. The service manager told me he had one in a few months back that had a bad isolator (back)&nbsp\\;from the factory, so this isn't totally uncommon. The bike had 280 miles on it when I dropped it off this evening, I hope I get to add quite a few more.
Quick Reply: Vibration free. Front isolator problem fixed.Pics
