Ness Big Sucker question
Old 06-11-2008 | 10:39 AM
JerseyDevil's Avatar
JerseyDevil
Default Ness Big Sucker question
Getting ready to do the Stage 1 upgrade and looking at A/C's. Was wondering how far the big sucker sticks out compared to the stock filter/cover? I rode a buddy's softail with a Hypercharger on it and damn that thing was uncomfortable with that sharp corner digging into my leg.
&nbsp\\;
&nbsp\\;
Old 06-11-2008 | 10:47 AM
gapwl3's Avatar
gapwl3
Default RE: Ness Big Sucker question
It sticks out a little more but isnt that noticable, but then I also have a round insert that i'm using as a cover so i have no sharp edges, plus i have 5" extension highway brackets to get my legs away from engine..
Old 06-11-2008 | 10:54 AM
SilverSpark's Avatar
SilverSpark
Just measured mine. Back of back plate to face of filter, 4 inches overall. Then you would need to add whatever cover, if any. I used a flat stainless steel round cover, same diameter as air cleaner, with stock trim ring. 1/4 inch.
Old 06-11-2008 | 11:01 AM
crabs's Avatar
crabs
I've got a ness big sucker with stock cover.No problems also got Ness bigshot Adjustable Fuel Injection Tuner.No need to adjust for stage 1 with v&amp\\;\\\\\\;h big shots.
Old 06-11-2008 | 11:06 AM
JerseyDevil
Cool, thanks guys. I kind of like my 08 teardrop shaped cover but the open element looks good as well. Can you use the stock cover? Not sure if the backing plate comes in to play with that.
Old 06-11-2008 | 11:11 AM
gapwl3's Avatar
gapwl3
I tried using my stock cover but it started to rub underneath the tank on my first test ride, so i immediately changed to the small insert cover.&nbsp\\; Plus I think the open element looks cool, gives it a custom look.
Old 06-11-2008 | 11:12 AM
SilverSpark
stock cover can be used with the ness b/s.
Old 06-11-2008 | 11:34 AM
crabs's Avatar
crabs
No need for stock backing plate.The only part you use is the stock cover.Just take everything of and bin it.Then install big sucker takes about 10 mins.
Old 06-11-2008 | 02:27 PM
ShoreRider's Avatar
ShoreRider
I have the AN BS on my FXDC with the MudMod cover and it doesn't get in the way at all, whether using my mids or forwards.
Old 06-11-2008 | 03:51 PM
JerseyDevil
Thanks fellas, yeah the MudMod looks great, that's probably what I'll end up doing.
One more, are all these high flow A/C's for Stage 1 relatively the same performance wise? (Ness Big Sucker, K&N RK3909, SE Stage 1 intake kit, SE Heavy Breather)
Quick Reply: Ness Big Sucker question
