30 tooth trans sprocket
Old 06-07-2008, 01:01 PM
madden23's Avatar
madden23
madden23 is offline
Default 30 tooth trans sprocket
Just wondering if anyone with a Dyna has installed this, ever since I got my Dyna I've felt it was geared too tall, a little sluggish off the line, 6th is not useful until 70+. Anyway I'm thinking of ordering one from evolution Ind. 297.00 for sprocket and chain. Any feedback. THX
Old 06-07-2008, 02:26 PM
TOMCENTRAL's Avatar
TOMCENTRAL
TOMCENTRAL is offline
Default RE: 30 tooth trans sprocket
Chech out the 49T clutch ring sprocket from EVO Ind.You retain the comp sprocket &amp\\; gearing is changed to 2.97 instead of 2.79.Regards,Tom
Old 06-07-2008, 02:58 PM
damadman's Avatar
damadman
damadman is offline
just change the Transmission belt sprocket from the stock 32 to a 30...&nbsp\\; andrews makes one.&nbsp\\; u can get it from dennis kirk for around 130.00 I got one just havent put it on yet(i was told there is enough adjustment with the stock belt too)
Old 06-07-2008, 03:30 PM
murphdog's Avatar
murphdog
murphdog is offline
ORIGINAL: TOMCENTRAL
Chech out the 40T clutch ring sprocket from EVO Ind.You retain the comp sprocket &amp\\; gearing is changed to 2.97 instead of 2.79.Regards,Tom
49 tooth? 40 tooth would give you 2.426.
Old 06-07-2008, 03:59 PM
madden23's Avatar
madden23
madden23 is offline
I thought you needed a different chain if you changed from a 32 tooth trans sprocket to a 30 tooth, Damadman quick install it so I know, lol. I don't want to buy the chain if there's no need. Evolution Ind. says you need a new chain and they sell it as a kit, included with the sprocket.
Old 06-07-2008, 10:12 PM
BoomSoon's Avatar
BoomSoon
BoomSoon is offline
I have been hearing and reading a good bit about these&nbsp\\;so being a new guy here I am also interested in this post.&nbsp\\; The Klock folks up in SD told me on TH that it would help exactly what you were inquiring about.&nbsp\\; The rpms are bumped about about 10%.&nbsp\\; However what they recc'd was with the 32 to 30 to also change the final/rear one from 72 to 70.&nbsp\\; Does that make sense?&nbsp\\; This way no need to mess with belt/chain?&nbsp\\; They have been doing this on all there baggers in the shop.&nbsp\\; Hope this helps.&nbsp\\; They did say it gives the bike the feel that it wants to get up and go much more noticeable.&nbsp\\; Very nice.
Old 06-07-2008, 10:18 PM
TOMCENTRAL's Avatar
TOMCENTRAL
SORRY,I ment 49tooth !
Old 06-07-2008, 10:20 PM
TOMCENTRAL's Avatar
TOMCENTRAL
Sorry,its a&nbsp\\; 49 tooth to equal 2.97 regards,Tom
ORIGINAL: murphdog
Chech out the 40T clutch ring sprocket from EVO Ind.You retain the comp sprocket &amp\\;\\\\\\; gearing is changed to 2.97 instead of 2.79.Regards,Tom
Old 06-07-2008, 10:22 PM
TOMCENTRAL's Avatar
TOMCENTRAL
This site is printing some weard lines. Regards, Tom
Old 06-07-2008, 10:36 PM
treeextractor's Avatar
treeextractor
treeextractor is offline
&nbsp\\;I installed the evolutions industries 30t&nbsp\\;on mine last year&nbsp\\;and&nbsp\\;love&nbsp\\;it.
&nbsp\\;
Quick Reply: 30 tooth trans sprocket
