which shocks for lowering a FXDB?
RE: which shocks for lowering a FXDB?
ok found one 11" shocks, it seems stocks are 12" anyone is sure bout that?
there are 2 models, almost the same but i dont understand the difference.
Order No. Ext. Length
In Ext. Length
mm Comp.
Length In Comp.
Length mm Travel*
Inch Travel*
MM Mnts. Spring No. Rate
lbs/In Rate
kg/mm 430 Series Shocks
430-4037B/C 11.00 279 9.64 245 1.36 35 E/E 1437-20B/30 230/275 4.11/4.91
430-4045B/C 11.00 279 9.64 245 1.36 35 E/E 1369-20B/30 300/350 5.36/6.25
last 2 numbers are lbs/in rate and the last one is kg/mm which one should i get, i weight 132lb and if i take my wife shes the same than me so 260lb two up.
thanks guys!! your a very good help
In Ext. Length
mm Comp.
Length In Comp.
Length mm Travel*
Inch Travel*
lbs/In Rate
I have Progressive 11" 412-4041C shocks on my '07 FXDB. \\;\\\\\\;\\\\\\\\\\\\\\; Whether or not you install the Heady Duty shocks pretty much depends on how much 2-up riding you plan on doing. \\;\\\\\\;\\\\\\\\\\\\\\; If you're gonna do 50% or more of your riding 2-up, I would go with the Heady Duty shocks. \\;\\\\\\;\\\\\\\\\\\\\\; I never ride 2-up and weigh 160lbs so the standard shocks are great for me on first (lowest setting).
[IMG]local://upfiles/22103/0B09B0B96EBF4AA7914A5F46644CA5C6.jpg[/IMG]
I went with the 11 inch Progressive 412's in HD (heavy duty). \\; Couldn't be happier with the decision. \\; Gives the bike the look I want and I haven't had any issues with bottoming out. \\; If I would have had the money and/or knowledge, I might have gone with the air shocks that JRK5892 suggested (he knows his stuff), but in order to save time and cash, I went with the Progressives. \\;
I have a vivid black 2008 FXDB so I got the black shocks to match. \\; I weigh 200 and the lady friend goes about 140. \\; Shocks are set to the highest setting and we rarely (if ever) bottom out. \\; Possibly once or twice going over bumps, and ironically, it doesn't seem to be tire/fender but more fender/belt guard. \\; The only complaint I have is the shocks set to firm and my LePera Bare Bones seat and I am nearly back to the hardtail that I just got rid of.
MikeK02048
06-25-2012 09:13 PM
