Decent motorcycle lift?
I did my 1k service and still need to do a few things that require a jack. What's a decent jack/lift to use for my dyna? I've read some pretty bad things about the red Sears lift. I know I'll have to purchase the dyna lift adapter kit as well. This thing will definitely get a lot of use.
Thanks
Thanks
RE: Decent motorcycle lift?
Not this crap again. Poor little red lift.
There's nothing wrong with the Red Jack other than maybe it isn't expensive enough for some people. I've been using one for almost a year and I have friends that have them and have used them for multiple years and they work just fine. But, if you'd prefer to spend some more money, there are others out there as well.
ORIGINAL: 2007fxdc
I read all the negative comments about the Searsred lift but got one anyway. Bought the Dyna adapters and for a non-lowered Dyna this lift works great. Only thing I can figure from all the bad luck some have had with the red lift is maybe Sears had a run of bad bottle jacks. Haven't had mine for long so I guess time will tell, I've used it many time tho' and no problems yet.
Al.
Al.
I use a red sears jack. Have had it for a few years now and used many times. Have had no problems with it. Bottle jacks in general have issues,mainly leaking fluid out. Be it a cheap harbor frieght or a Blue Point. But usually filling the jack with oil and bleeding it they work again. Knock on wood the red sears jack I bought I haven't done anything with but use it.
Later,
Josh
Later,
Josh
I've had a red Sears jack for almost 2 years now without a problem. I'm not sure about others but I never let the bike sit on the lift hydraulics. As soon as I get it up to the level I want, I got directly to the lock and off the bottle jack. Mine was so poorly made that I couldn't even get the bolts to go into the welded nuts that hold the bottle jack on. Had to chisel one off and replace with a locknut. But it still works great. I also always use a strap to hold the bike on the lift as insurance.
