Help w/diagnosis--bad MPG
RE: Help w/diagnosis--bad MPG
True the adjusters will add or subtract fuel,depending on which way you turn them,but since it's load based you can't make it run leaner than stock, if they are turned all the way counterclockwise you are adding a 0% addition to stock demands all the way clockwise 50%, I was just trying to reassure him how easy it is to adjust, so technically you can really only add fuel above stock demands, yoo cannot make it less with this device..
Done. Got a new fuel line at NAPA...exact copy FI line as the original and just put on the original clamps and heat shield over it. $5 NAPA vs $47 Harley Dealer. I was actually going to get one at the dealer but both in town had NONE in stock and would have to order. After hooking up the new line I did all kinds of little tests to ensure nothing leaked...it's on there solid at both ends. May someday go with a stainless steel braided hose if anyone knows of one that fits.
I took off the SERF. Cleaned the black off all the plugs and inside the exhaust a few inches. Regapped the plugs; they are fine now and looking new. Fired it up and it runs smoother now I think...idle more stable, still great throttle response, and after a good warmup I took it around for a ride. No pops on decel, solid power (no less or more than before) and smooth all the way through the power/torque bands.
I think I'll leave it this way for a couple tanks, checking the plugs each fill-up for signs of leanness, and see what MPG I get. I can't see any reason todo anything more if it's not lean now, it runs great!
On my former bike('05 VMAX) I had a K&N with full race exhaust and never had to jet because the altitude here took care of it for me. Now, that was a carb bike and at Sea Level I would have had to upsize the jets. With FI on this Bob, I'm not so sure?
For those with the SERF...I couldn't even get to the adjusters...do the halves just pry apart?
One SERF on sale now, cheap...pm me if yacould useone
hang on there, bros.....
I would NOT install an XIED if the bike is already running rich. The XIED will richen his mixture even more than it is now in open loop.
At that altitude, install a K&N filter, remove the fueler, and go. Betcha anything you will increase mpg by 5-7 miles and your plugs will be less black after a nice long highway ride with your new set-up
Try it...
Try it...
ORIGINAL: kansaskid72
Again, out of curiosity, why replace the $140 Stage 1 SE/AC with a K/N filter? Is there a big advantage over the SE one?
Received 4,807 Likes
I agree the K&N is more durable. Flow is a little better with SE.Here are some published flow rates for air cleaners.
HD stock - 171CFM
Stage 1 Big Sucker - 200CFM
Stage 2 Big Sucker - 250CFM
Kuryakyn Twin Velocity - 270CFM
E-3014 = 248 CFM RK-3009 kit
E-3037 = 301 CFM RK-3910 kit
HD-0800 = 231 CFM SE replacement
Doherty Powerpacc - 287CFM
SE Air Cleaner - 287 CFM
Zippers - 321 CFM
Woods Carbs - 4 models 235CFM upto 340CFM
BC Overflow - 800+CFM
HD stock - 171CFM
Zippers - 321 CFM
It definitely sounds like your bike is running rich. I have a buddy with an '05 Road King and we rode from Fort Walton Beach, Florida (home) to Brunswick, Georgia last weekend. He got an impressive 26 mpg. He put some kind of custom made/one off pipes on it awhile back. I told him over a month ago the thing was running too rich, as you can smell it when it's idling. I think he's finally convinced. lol
