96 oil capacity with filter
RE: 96 oil capacity with filter
Dealer says 3. On the other hand, it's difficult at best and impossible to get a reading when hot and letting it set. To much oil on the stick when you pull it out to even get a reading. I will try again to get some kind of reading. I did my 500 mile oil change and put 3 in.
If your dealer is telling you 3 quarts he is steering you wrong. 2.5 quarts for a wet oil change, 3.0 for a dry. Page 1-11 of my manual says "Use wet capacity for engines that have just had the oil drained. Use dry capacity for engines that have been disassembled, cleaned in solvent, and dried." I would go about 2.25, then run it a little, check it, and fill from there. If you go over 2.5 I would be very surprised.
Thank you all for not flaming me!
I just drained some out by eyeballing, I'm sure not a whole 1/2 qt. came out. I rechecked the level, cold engine and I can now actually get a reading on the dip.Go figure! It reads jut above the full mark. I will check hot the nextdriveI do. Thanks for steering me straight! Why are these stealers Dicks??? And yes, I will NOT fill that full again.
