Install ?
Old 05-27-2008 | 09:31 AM
blacked out's Avatar
blacked out
Default Install ?
when installing a set of pipes and big sucker intake along with the PCIII d oyou use the O2 sensors in the pipes ?
Gordo
Old 05-27-2008 | 09:33 AM
USMC7236's Avatar
USMC7236
Default RE: Install ?
Nope. PCIII comes with O2 sensor eliminators. You can just leave the O2 sensors in the pipes, or remove them and get plugs to put in the bungs.
Old 05-27-2008 | 09:46 AM
blacked out
when I bought my pipes the short shots I purchased some bungs that screw in to the pipes so I guess that answers that question. Now if I remove them fro mthe bike is there a connectore that I can just unplug them > or is there cutting invlolded. HAs anyone just left them in the pipes and if so is there any problems ?
gordo
Old 05-27-2008 | 09:56 AM
USMC7236's Avatar
USMC7236
ORIGINAL: blacked out
gordo
No cutting involved. I left mine in for about 2,000 miles then pulled them when I replaced the exhaust. If you leave them in (no real reason to), make sure the wires are zip-tied out of the way. I'd pull-em out though.
Old 05-27-2008 | 10:06 AM
blacked out
I would like to pull them but do you have to cut wires or is there connectors that unplug ?
gordo
Old 05-27-2008 | 10:41 AM
joe.1955's Avatar
joe.1955
Both sensors have connectors that unplug.
Make sure to tie off the connectors / wiring so they don't hit the engine.
Old 05-28-2008 | 09:49 AM
blacked out
thanks everyone
gordo
Old 05-28-2008 | 03:21 PM
Righteous's Avatar
Righteous
When you install the PCIII, youwill disconnect the O2 sensors at the plug. The PCIII comes withO2 sensor eliminators that plug into the wire harness where you removed the O2 sensors. You can then install bungs into your pipes where the O2 sensors were.
Scorpza
Exhaust System Topics
05-27-2014 10:18 AM
Sportster330
09-04-2013 03:33 PM
Zapper
11-12-2008 02:57 PM
shimmon
05-02-2008 07:24 AM
waterman7474
09-21-2006 11:37 AM
Quick Reply: Install ?
