Screamin Eagle Triple Platinum Plugs and Wires
Is it worth the very small expense to run these plugs and wires on a basically stock bike? As far as performance mods go I've got the SE Air Cleaner with K&N and open element cover, SE Pro II slip-ons, and the Stage 1 download.
I've got to assume that the stock plugs and wires are more than up to the task of handling what's already there, however I'm never one to back down from having race engineered parts in place to handle all conditions.
Just looking for some opinions OR some dyno proven numbers if you have them.
I doubt that you'll notice any difference from a set of plugs and a set of wires. I did swap out the stock wires for the SE red ones, just because they look better than the stock black. Unless you have a really tweaked motor, the stock plugs and wires should be no problem.
