More on cruise drive pulley
http://www.bakerdrivetrain.com/cruis...ex.htm#pullies
30-tooth or 31-tooth h-d® 2006-up cruise drive™ pulleys
Get more oomph from a throttle-wick on your 2007 stock Harley-Davidson FL. Our 30-Tooth or 31-Tooth transmission pulleys effectively ‘gear down’ the bike to optimize the performance in two major ways.
First, you’ll get more torque and power from the take-off gears. This remedies the common criticism of the new bikes being a little sluggish off the line for some riders.
Second, you can utilize the 6th gear at a slower, more reasonable highway speed for a more comfortable RPM. These pulleys bring the cruising gears down a notch for finessing your ride.
Performance details are as follow:
[ul][*]Increase Rear Wheel Torque (30T- 7% Increase / 31T- 3% Increase)
Cruising RPM 6th gear (75MPH) 30T @ 2830 / 31T @ 2756
No more lugging the motor in 6th gear at lower cruising speeds (60-70 MPH) [/ul]
Note: Will require the use of a 1 tooth shorter belt (For example: H-D p/n 40056-07 is for FL) 2 ¼” special Pulley nut socket required for replacement available from Baker Drivetrain. p/n 94660-07BD
2.25" pulley nut socket wrench
For use on 2006 Dyna and 2007-up Big Twins. Visit the tools page for more info:
http://www.bakerdrivetrain.com/tools...iseDriveSocket
2-1/4" Pulley Nut Socket Wrench p/n 94660-07BD
And the Andrews pulley can be found here:
http://www.denniskirk.com/jsp/produc...0813&mmyId=
markrumsfield
17
05-19-2008 04:36 PM
