Vance and Hines 2-1 Propipe HS **UPDATED**
I purchased this pipe a little over 4 months ago for my 03 wideglide. It delivers awesome performance and sound and up till now has looked great as well, however... yesterday I noticed what I thought was a reflection of some dirt in the parking lot on the rear section of the pipe. Upon closer inspection, it turns out to be a rust colored haze on the under side of the pipe. After riding it home I see that it is creeping up around the top of the pipe as well. I tried my best to clean it last night to no avail! This morning I called V&H tech dept. The guy tells me this is a common problem with this pipe as is it was made prior to them coming up with anti blueing technology! They are being very helpful so far and I have a call in to a manager in hopes of trading my megaphone for a new one. The reason for this post is to pass down some info to anyone thinking of buying this pipe. It is a great pipe, but if you purchase it, take some time to install some "chrome gaurd" which can be purchased from JP Cycles. Apparently, according to V&H, you take the innards of the megaphone apart, put 2 coatings of this "chrome gaurd" on the inside of the chrome and this will act as an anti blueing agent. There is, unfortunately, no cure for an already blued, or in my case browned pipe however. We'll see what happens with the sales manager!
RE: Vance and Hines 2-1 Propie HS
same thing happened to me. I didn't get anywhere with getting any sort of free or discounted replacement... I just bit the bullet and bought a new one. The guy told me the same thing, and I did get that stuff from J&P... works great.
I only wish they would have provided such usefull information up front.
1 Post
I'm curious to see how V&H handles this.
Not to change the thread, but I went thru the same kind of story with some ceramic coated Hooker Headers for my truck.
Called tech and told them what was wrong, tech guy says, "oh, yeah we've been having trouble with that same problem, seems the ceramic is too porous and allows moisture in, causing the rust."
So I'm thinking if they know there is a problem, they'll replace it/make it right.
WRONG.
Couldn't be farther from the truth.
Offer to have me send the headers back and they'd re-do them for $350!(the same cost as getting a new set done).
I told him where to get off and never bought any other part from them and advise everybody who'd listen to do the same thing.
Back to your original programing....
WRONG.
ORIGINAL: beendad
That's what I'm talkin about! Would have been nice to know before shelling out big bucks for it! How far up the ladder did you get before giving up on them replacing?
BTW - if anyone is interested in buying my old megaphone - you know, for the baffle most likely ... you know where to find me.
ORIGINAL: thrillseeker
if you mean when taking the original off to put on the replacment... yeah, it took a little elbow grease to work it off.
ORIGINAL: labfreak
Any of you guys have trouble with the clamp that goes around the muffler at the collector. ?
I did.
I did.
