Options on replacement tyres for Fat Bob
Old 05-20-2008 | 01:19 PM
mud's Avatar
mud
muderator
Default RE: Options on replacement tyres for Fat Bob
ORIGINAL: Dodzi
ORIGINAL: Dodzi
Ok so someone out there must have worn out the OEM tyres fitted to the Fat Bob. Whats the options for replacements and whats the thoughts on them?
Sorry I thought I did.
The reason I ask is cos of the unusual size on the front of the Fat Bob and I thought with the weather over there someone would have done the mileage to wear out a pair. I'm used to running a GSX1400 and they are usually done for in 7-8000 miles.
Again I apologize - just trying to get an idea of what replacements may have been brought to the market we may not have heard about over in the UK yet.
No need to apologize Dodzi.
Your query was fine.
I don't have tire info for the Fat Dynas,
someone will probably answer you. Maybe.
mud
Old 07-28-2008 | 07:32 AM
Dodzi's Avatar
Dodzi
OK - I've had the bike for 4 weeks - done about 3.5K miles and they are starting to flat off a bit so I was wondering if any of the tyre companies were offering tyres of the same dimension as the originals as alternatives to the dunlops. Looking for tyres which would improve grip rather than lasting longer. I have had reports that venoms grip well but not sure that there are any which would fit the big boy.
Any opinions?
This is a query for FXDF replacements only.
Old 07-28-2008 | 08:52 AM
low_n_slow's Avatar
low_n_slow
Actually you can stick a 200 on a stock rim and it will fit with out any modifications.
There is a guy on here that installed a 160 on the front ( I believe)
and a 200 on the rear with out any modifications.
This is for a FAT BOB
Old 07-28-2008 | 09:01 AM
FastHarley's Avatar
FastHarley
Former Sponsor
1- your road conditions are not the same as here in the USA. Compounds make a difference in mileage. Looks or performance is your choice. More performance = less mileage. What is important to you. Larger (wider) the tire = more friction. Weight to HP ratio should determine how much rubber you need to brake it loose. If you wants looks than all is up to you.
Old 07-28-2008 | 03:54 PM
Border Cop's Avatar
Border Cop
The 2009 Fat Bob has a new thread pattern.&nbsp\\; So that makes 2 choices for OEM tires.&nbsp\\; Otherwise, stick a rear on the front and back.
Old 07-29-2008 | 05:26 AM
Dodzi's Avatar
Dodzi
No one used anything other than OEM then?
Old 07-29-2008 | 05:30 AM
Dodzi's Avatar
Dodzi
need to keep the same geometry
Old 07-29-2008 | 05:31 AM
Dodzi's Avatar
Dodzi
and putting a rear on the front is a deffo no no as this mean the tyre will not come up to temp
Old 07-29-2008 | 05:40 AM
Dodzi's Avatar
Dodzi
Avon do a Venom and a Cobra - anyone fit them?&nbsp\\;
Old 07-29-2008 | 05:41 AM
Dodzi's Avatar
Dodzi
Tread pattern is only to show the tyres off - want function not looks
Quick Reply: Options on replacement tyres for Fat Bob
