brake and clutch
RE: brake and clutch
These levers are pretty easy to change.
The clutch side:
[ul][*]On the left side of the frame, slide the rubber boot up the cable to expose the adjustment.[*]Loosen the jam nut, then turn the adjustment nuts to shorten the length of the cable housing.[*]Use a pair of external snap ring pliers to remove the snap ring from the pin on the clutch lever.[*]As you remove the lever from its perch, you will see another pin which secures the cable to the lever. Slide this pin from the lever.[*]Install the new lever in the opposite order of the above[*]Turn the adjustment to lengthen the cable housing. You should endup with about 1/8" of play in the lever when properly adjusted.[/ul]
Note: You may want to get a couple new snap rings from the dealer as the old rings stretch easily and may not be suitable to reuse.
The brake side:
[ul][*]The brake lever is removed the same way as described for the clutch lever.[*]Be careful of the brake light switch which is recessed in the brake side housing. It is very easy to break.[/ul]
Hope this helps.
The clutch side:
The brake side:
Hope this helps.
New levers should come with instructions. I just replaced mine a couple of weeks ago. Much easier than it looks. Basically, do what jmpman said. I also used a marker to make a mark on the clutch adjustment nut and counted how many turns to loosen it and turned it back the same number of turns to tighten it - then fine adjust from there. If you don't have a pair of snap ring pliers, get some, it will make this and other jobs easier. I picked up a pair of Craftsmen that are reversible so I can use it on both types of snap rings. It also came with interchangeable tips so I can use it with different size rings. If you aren't too rough with the snap rings, you should be able to re-use them. As for the brake lever, be careful as jmpman said. Not too difficult though but work it such that it slides out fairly easily. If you find yourself forcing it, it's probably not in the right position to come out. You can use the new lever as a reference to see how it is positioned in there and you'll see how to move it to get it to slide out. Took me about 20 minutes to swap mine out and most of that time was dealing with the clutch cable.
