FXDP Floorboard Kit on 06 Later Dyna
#41
If you're going to go that route, I highly recommend this shift lever..
http://www.waltersworkshop.com/exten...ft-levers.html
#42
#43
Here's a pic of the bike these boards actually came on. Dig that seat!
http://www.totalmotorcycle.com/photo...naDefender.jpg
#44
parts list
1. parts you don't need:
7710W (is used to secure the stock shifter rod to the crankcase)
7736 (is used to mount the new shifter rod to the new shifter lever)
7744 (is used to mount the new shifter rod to the gearbox shifter lever)
2. part which is missing in the list:
33711-02 prake pedal
3. according the FXDP parts catalog the footboard assembly (P/N 50632-85) comes
without the footboard pad (P/N 50614-91A). If you want to, you can skip these pads
and buy other (multi-fit inserts)
Kind regards, René
#45
I don't use a heel-toe shifter with my boards. My single lever leaves more space on the left board, and I prefer to shift the standard way. The large brake pedal robs some room from the right one, but IMO it gives you better control than the smaller pedal used with pegs. The variety of foot postions with boards is a big plus, especially with highway pegs.
BTW- I have forwarded this thread to a whole bunch of guys asking about boards...best one I've seen. Good work, Keeg!
#46
A few corrections according the J01921 leaflet:
Kind regards, René
Kind regards, René
#48
Pockets2000 sent me the pdf file of J01921 and I've uploaded it to one of my web sites. You can download it by clicking here.
#49
Hey Guys,
Since my original post, I have changed the shifter configuration as well.
I added an extended lever from Bubba's Brake as my heel shift. This came in at just under 10" long and provided the most clearance on the footboard. I was going to try to go from the mid spline with this shifter, but found it wasn't long enough to provide ample clearance on the board. By my measure you would need a shifter approx 12" to feel comfortable to go this route.
For my toe shift, I cut down the stock shifter and adjusted accordingly. Just need to slot it to match the rear. Also adjusted the heel shift to sit just above the board so it is very minimal foot lift to upshift.
I also have the parts list pdf file I can email if anyone needs it.
#50
