Advice for newbie
Advice for newbie
I have the SE Stage 1 A/C kit and the SE slip ons on my '06 Street Bob. I just purchased some V&H Big Radius pipes and was wondering what, if anything, I have to use for the EFI. I had the dealer do a one time download when I put the slip ons on but not sure if I need something else now. Thanks in advance for any help...
RE: Advice for newbie
I did pretty much the same thing, cept I used V&H BSS. It should be fine, tho the dealer did ask me if I was having any issues with it and said I'd eventually need a new tune.Took about600-800 miles and it seemed to be popping quite a bit. I put in a PCIII and it stopped it.
you will need a tuner...
if your done with all engine mods and fuel pack might be good for you. but if you think you might do engine work or change pipes later down the road you may want to think/search for information on the SERT or PCIII!
i would, and did, go with a PCIII from fuelmoto... you'll hear that alot on here.
harley on,
harley on,
ORIGINAL: jrock28
Thanks for all the advice, I think I'll try to run it with the download that's on there and then get a PCIII if I need it.
You don't need a 'tuner', that's B.S.....
If you got a stg 1 download to your ECM ( there is a part # for that, check it) You will be fine.
Try adding IED's, you wont regret it, check nightrider.com (I am not an agent, just a happy customer!)
Do your homework, yer gonna find a bunch of opinions on the need/no need for SERT, PCIII, T-max etc.
If you opened up the intake, as it sounds like you did with a hi-flo AC, then be sure you at least got a stg 1 download.
Have fun!
Have fun!
I just bought a set of V&H short shot staggereds for my 05 wide glide. I also have a SE stage 1 (a/c and ecm flash). After reading a really good post on this topic yesterday, I decided to call the HD for their input. The response was that it 'might' run a little lean in 2200 rpm and at the tops of the rpms. I am with you, feel out the bike for a while.
trappermarc
03-08-2018 02:56 PM
drumer66
04-08-2007 04:09 PM
