Chrome Rocker Covers
RE: Chrome Rocker Covers
ORIGINAL: AmericanIron
Piece of cake to do just the uppers...if you do the upper and lower piece...its a little more involved. Get a service manual if you do.
Here's the link to installing the S&S Chrome Rockers, the HD or others are pretty much the same:
http://www.sscycle.com/modules/instr...ds/51-1052.pdf
ORIGINAL: DGlide04
Since the Twin Cam rocker covers are wedged shaped, you could do just the uppers, but it might look a little odd to have the wider wedge on the bottom cover showing against the chrome upper. I did had mine powdercoated over the winter and changed them out, not overly difficult, but leave yourself enough time to get it right. You will want to take off the gas tank to be able to get to the bolts on the rocker covers and while you're at it, depending on the mileage, you'll want to change the breather elements out since the upper rocker is off anyway.
It's a really simple job. It's not necessary to remove the tank if you've got the right tools. You can take the rear tank bolt out, raise the rear of the tank and prop it up. This saves a lot of time. After removing the top cover, you'll have to remove the rocker assembly. Start by loosening the breather bolts first, then the rocker bolts. With the rockers out of the way, then you remove the bottom half of the box. Removal is the easy part, installing is where you really want to take your time, because the lifters need to in the lowest position before reinstalling the rocker assembly. Have the bike on a jack, drop it into 5th so you can roll the rear tire to roll the motor over to lower the pushrods/lifters. As mentioned above...get a manual. It's the absolute greatest addition you can add for your scoot. It'll walk you through everything, step by step with all of the torque specs.
