V&H Quiet Baffles for Short Shots
Another vote here for the quiet baffles! Thanks fellas for the good info about these in past threads - everything was 100% on target. I just put them on yesterday and I like 'em. The sound is good, much lower and deeper at idle and low rpms, but still has plenty of bark when you get on it. They also made a considerable difference with low end torque, with better throttle response and the bike just seems to run better with them. Got mine from Eastern Performance for $70 with free shipping, and they sent them out the same day.
RE: V&H Quiet Baffles for Short Shots
I have Short Shots installed with no baffles (at least I don't see anything when I look into the end of the pipe.) They're pretty loud and sound excellent. I wouldn't mind quieting them down just a hair.
Can you install these with the pipes on the bike? Is it a matter of removing the heat shields, inserting the baffles, screwing them in (?) and reinstalling the heat shields?
ORIGINAL: SgtThump
ORIGINAL: WildBillAce2
Hey Thump, yes you can but when you put the heat shields back on you have to leave off one of the clamps to get them on without removing the pipes from the heads. Three is more than enough to hold them on anyway. You kind of have to rotate the shields on and it's a tight fit but I did it a few times without problems.
Are these what I need? I'm not looking for the "quiet baffles." Just regular baffles to quite it down some.
http://www.ridegear.com/rg/item/F-29...t-Baffles.html
Chris
Chris
ORIGINAL: SgtThump
Chris
Chris
Thump, if you want performance baffles with good sound then I'd go with Big City Thunder: http://www.bigcitythunder.com/pages/product-fit.html
But the V&H quiet baffles only make it quieter and deeper at idle and low rpms. When you open it up they are almost as loud as stock. If you aren't running any baffles at all right now then you will like the torque increase when you put them in.
