Greasy goop on Voltage Regulator
I noticed a greasy goop on the bottom of my 07 Street Bob's voltage regulator tonight. It looks like dirty vasoline. I can't see any leaks from the oil filter which is located directly over it. I can't see any oil coming from the various drain plugs under the bike. I'm totally confused where this greasy goop is coming from.
Any ideas?
Any ideas?
RE: Greasy goop on Voltage Regulator
ORIGINAL: USMC7236
Do you change your own oil? When removing the oil filter the oil drips all over the voltage regulator. It could be just residue from this.
Changed my oil about a thousand miles ago. I've washed the bike several times since then. I have also had the voltage regulator off since the last oil change to install a new exhaust. This was my first thought but I think I would have noticed it before.
Also can't see anything dripping from the front axle and don't remember running over any slime on the road but that is always a possibility.
Thanks to all for trying to help.
ORIGINAL: SeeNoSun
Heat sink? never heard of this. Is it ok to clean it off?
ORIGINAL: MK249
Heatsink. There from the factory and used on the bottom of almost all voltage regulators and other electrical items to help dissipate heat.
