Low Rider Battery cover hurts
Hey guys, before I go and fabricate something I thought I'd ask if you know if they make anything for this little problem. My wifes low rider has a corbin gunslinger seat and she is complaining about the corner of the battery cover poking her in the leg. Got anything?????
RE: Low Rider Battery cover hurts
I installed a pair of Kuryakyn offset extensions to get more length, but they also made my sitting stance wider. Worked to get my legs off the horn and a/c. Something similar might work to get her off the battery cover.
[IMG]local://upfiles/23085/9B5F97D894404885AB97A4C3E897927C.jpg[/IMG]
[IMG]local://upfiles/23085/E2A5D60BA4A14B8585239B1B2BD4BDDD.jpg[/IMG]
The stock cover has flat sides and failrlysharp edges (I used to have that one). You could switch to the other one from the catalogue like I have now which has smooth, rounded edges (part #66192-99).I changed it because I didn't like the flat sided one,butlike 96 Wide Glide said, my leg doesn't go near it.
Sharp edges: http://i211.photobucket.com/albums/b...h3-2007015.jpg
Smooothegdes: http://i211.photobucket.com/albums/b...on/Dogs040.jpg
It's in the Harley accessories book. Maybe there's a way you could put some padding over it while riding, like a soft terrycloth small towel in black that can be removed whenever you want. Cheap solution always better than replacing entire pieces IMHO.
~Joe
~Joe
